Any update on the installation?
Or did the rain kick you into next week?
Cost per Watt in SF Bay Area?; system cost difference with SolarEdge vs. SMA?
Sunpower offer to me was at 4.9/wtLeave a comment:
chunglau, would you mind pm'ing your solar installers for the 3.65-3.85 quotes?
quotes i recieved:
sunrun 12x260 REC @ 4.12/watt
solarcity 11x250 CASolar @ 5.10/watt
sungevity 10x250 REC @ 4.93/watt
sunpower 12x345 @ 5.15/watt
bay area, fremont.Leave a comment:
PG&E took about 10 days.
On the monitoring....
If you have them do it, make sure you get full, installer level access. If not it's pretty limited in what you can see/do. That's one of the reasons I did it myself. (not that they refused, it never got to that point)
It does not need to wait for PG&E that I know of.
Good luck.Leave a comment:
The installers themselves were very competent and efficient. They took minimal breaks & seemed to take pride in their work. There was no damage, mess, etc.
I actually ended up setting up the monitoring myself, handled the interaction with Solaredge, etc. It's not that hard and I wanted it done. The only issue I had with the actual installation was that what was supposed to be one day turned into two, working 'til dark the second day.
Curious if you mentioned me when you contacted them?
Keep us informed as you go.Joking. No - I haven't mentioned anything to them about this forum. I'm paying them a bunch of money - so I expect them to get me up and running on SolarEdge - or at least provide me with clear instructions on how to get going with monitoring. But I assume I will have to wait awhile before pg&e give the greenlight and "flips the switch"? And yes...I will report on how it goes.
Hi Bikerscum,
The installers are coming tomorrow to do the install. Watch...it will rain! Other than the delays in getting the monitoring up and running - any other things to watch out for? Any damage to gutters, or any else I should pay attention to? Thanks.
(p.s. - this would be best sent as a PM, BUT......still can't PM you. Oh, the rules of SPT......)
Keep us informed as you go.Leave a comment:
(p.s. - this would be best sent as a PM, BUT......still can't PM you. Oh, the rules of SPT......)Leave a comment:
@chunglau @JCP Thanks, got your PMs! Unfortunately, that company doesn't service my area, but the reviews sounded nice. I'm sure I'll find something comparable with the other folks.Leave a comment:
I have received quotes from two companies that are well-rated that are lower than the other three quotes. The prices ares $3.65 to $3.85/W for a roughly 4KW DC system. Panels are 14xLG280 with Enphase, or 16xSunPower SPR245 with Sunpower-4000m inverters. These are not the latest model panels, but should be good enough.Leave a comment:
Well done! Let's hear the details. What panels, kwh, inverter, price and price per watt did you go with?
I got quotes from 5 south and east bay installers, all highly rated. All had cost/kwh above $3.75 for a 3.7kw system. One was over $4/kwh. I didn't check the electrical contractors that also do solar. I have a feeling they might charge less than the pure (or primarily) solar installers.Leave a comment:
I can't PM either. YES, I went with a company highly rated on Yelp out of Pleasanton. That should help you find them. I liked that they came out and walked the roof before proposing a solution. But, we'll have to see how it goes. Install will happen sometime late in November. I ended up with 14 Mits 265kw panels, and a SolarEdge 3800. I decided I want panel-level monitoring, and free monitoring (heard Enphase charges at some point? Don't know if that's true or not). I wanted to go with a larger inverter, for possible future expansion. But my old electrical panel isn't up to it. And the cost to beef up the amperage is exhorbitant. PG&E guesstimated $8k+ including trenching. Decided to pass on that. Price came in just under $3.75/watt. Don't know if I could have done better. But I ran out of time and patience to negotiate further.
The install did eventually get done (still waiting on the monitoring) but it took a lot of prodding on my end.
Things should slow down a lot at the timeframe you're looking at, they probably won't be so busy.
I most likely talked to the same company. I did not like their high pressure sales tactic. I especially did not like how they started with a really high bid, only to drop it by $0.50-0.60 after learning that they lost the deal and bad mouthing other company. Not very pleasant...Leave a comment:
I can't PM either. YES, I went with a company highly rated on Yelp out of Pleasanton. That should help you find them. I liked that they came out and walked the roof before proposing a solution. But, we'll have to see how it goes. Install will happen sometime late in November. I ended up with 14 Mits 265kw panels, and a SolarEdge 3800. I decided I want panel-level monitoring, and free monitoring (heard Enphase charges at some point? Don't know if that's true or not). I wanted to go with a larger inverter, for possible future expansion. But my old electrical panel isn't up to it. And the cost to beef up the amperage is exhorbitant. PG&E guesstimated $8k+ including trenching. Decided to pass on that. Price came in just under $3.75/watt. Don't know if I could have done better. But I ran out of time and patience to negotiate further.Leave a comment:
