I wouldn't contest the above, I tried to always say "your situation may vary" in my suggestions.
HOWEVER....
"1. any (panel) addition to a system, added in any orientation, will increase the instantaneous
system output, full sun, or complete cloud cover"
Yes it will, and a simulation should be used to see the exact results. Just a matter of
adding up each panel group on an hour by hour basis.
"2.) Safety first: Any system changes must trigger a system review for impacts on the entire system"
Certainly.
"3.) Bruce: Most commonly, "Nameplate Rating" refers to the S.T.C. rating of the panels used. "
That answers my question. That rating system pretty much tracks the "all south" design
methods. It would be of minimal relevance to a multi oriented system.
"5.) One goal of any solar design is usually most bang for the buck."
"USUALLY", but not always. A lot of people rank money very highly; I am not one of them.
"However, to think that east-west arrays or splitting arrays to off south orientation will
be more cost effective simply and solely because it will make the daily production peak(s)
a bit lower and also increase output some at other times of the day (thus, flattening the
curve and putting "more area under the curve") is, in almost all cases, incorrect."
Here "ALMOST" is the key term. DO analyze your application, and DON'T FORGET
THE CLOUDS. My particular E-W payoff was MUCH more cost effective than the
south only portion.
Its pretty obvious that designs have mostly been driven by the idea of getting the most
from the precious PV panels, generally in a mostly sunny location. That is not what is
going on here, in the frequently overcast north central, and now that the cost of panels
has become a SMALL FRACTION of the total system.
Nor does this "science project" depend on a guaranteed return on investment;
somewhere near breaking even will do for this round. However, it is doing well.
My inverters were sized big enough to do the job (heat my house). I can think of 4
reasons why mine can't be any bigger. All that is needed, is to keep them loaded.
It became fast apparent that clouds were a make or break consideration. I haven't
seen ANY design methods to deal with clouds, just to write off those (frequent) days.
I decided that a lot more panels were needed to bring up power in marginal weather.
But MORE south facing panels would be of little benefit in good sun, just cause more
clipping. INSTEAD those panels would be oriented to produce when the south facing
panels were at minimum. This round may not be optimum; some south facing panels
might get moved someday. But a clamp on ammeter used in all situations has shown
it was a great first guess. In truth, there are enough panels to keep the inverters at
clipping all day long in good sun. But that is just another benefit of keeping output
high on so many overcast days.
Bruce Roe
HOWEVER....
Certainly.
south only portion.
Bruce Roe
