How many panels do I need?
Any human inhabited house in the USA, is regulated by county/city building code, unless it's on the national historic register. You cannot alter the structure or increase room size without a permit. Or you are breaking the law. Some sort of admin law, that exists to extract money from people with the nerve to build. I had to get a county permit, and an engineering approval, for the 12' pole to hold my solar array. The pole mount was certified by it's mfg, but the county needed a engineer (for $250) to tell me to auger a 24"w 10'd hole for the pole and fill it with rebar & concrete. Or they can make you take it apart and show the wires inside your wall are done properly.
But that's the rules. Electric company in my area will only install poles and wires to a permitted structure. So I could not even get power to my gatehouse.
So vote some different county officials in that write rules your way.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Sergent first thing is if you have grid power available, you do not even want to consider going off-grid with a battery system. The reason is simple, if you go in with a battery system you will be paying 5 to 30 times more for electricity than you do now buying it from the electric company. There are a few rare cases where going off grid can ever pay off as it takes some very special circumstances like living like a hermit and a recluse.
Now before you even consider going grid tied or off-grid, the very first step is a complete remodel of your home, upgrading all appliances, lighting, and all mechanical systems in addition to life style changes. For every dollar you spend on upgrades will save you 2 dollars on the solar PV install
Upgrades mean replace all windows and doors, add insulated siding, insulation in attic and crawl spaces. Replacing Air Conditioning with highly efficient dual fuel heat pumps. Getting rid of all electric hot water heaters and cooking and use either LP or NG, replace all fixed lighting fixtures with fluorescent and all bulbs with CFL. Finally upgrade your refrigerator.
Once you get all that done first, you may find out you do not need solar PV, and if you do, well you just cut the cost down by 50% or more. The upgrades to your home are equity positive meaning the value of your home goes up more than what you put into it. Solar PV in all states except states like CA and AZ is net negative.Comment
So vote some different county officials in that write rules your way.Comment
I am a homebuilder in Houston and of course in the city we have extensive inspections. In the county for new structures there are now 4 inspections.
In your case I doubt you would need it. Just ask. It is no big deal and won't open up a can of worms to inquire. I am building myself a place in the country and it is a relief not having to deal with the building bureaucracy for once.
Your problems lie elsewhere from what I read...(and I am a newb at this).......sounds like you need to get your power consumption down as Mike or one of the other pros said.
cheers,
jimComment
Sarge.....as of 3 or 4 months ago Texas started doing some very minor inspections outside of city limits...they are minimal and mostly pertain to new structures and septic systems.
cheers,
jimComment
1800 x .8 (a 20% loss in power from being heated by the sun) = 1440
1440 x 5 hours = 7,200Wh per day
7.2 KWh x 30 days = 216KWh per month expected harvest, with perfect sun angle
So, installing a Grid Tie (no batteries, just PV and Inverter) system, looks like it could make a big dent in your electric bill, with a yearly average net meter program. If you add batteries, you increase the cost a fair amount, increase maintainaince, and decrease efficiency a bit.
If you can take and input your roof direction and pitch (angle) into the PV watts website, for your area, you will get a much better, climate adjusted (cloud cover) estimate for your area.
http://www.pvwatts.org/Lawrence Lile, PEComment
