The dimmer is on the same circuit that the gateway is on because that's where my internet switch is and there really is no choice of moving it.
Talk to me about TED
Originally posted by HX_GuyThe dimmer is on the same circuit that the gateway is on because
exotic like fluorescent? If the dimmer is a very simple phase controller, check if it has
any kind of RF filter. Like, a coil wound around a ferrite rod. If not, just using a filtered
dimmer might fix it.
Failing that, even a minimum type filter box could do it. 2 wires in, 2 out, lots of them
around here. Try putting it at the 2 wires from the power; the output side goes to the
dimmer & the light fixture (only). Probably won't fit in a small wall box; need a double.
Pretty aggressive here. The words "can't" and "rewire" just never go together. Bruce RoeAttached FilesComment
The light is an incandescent fixture using a Leviton dimmer from Home Depot, nothing fancy. Looks like this, except only 3 total wires (the picture from Google is for a 3-way switch)
It's really not that big a problem so I'll just leave it alone. What is more bothersome is that the TED software shows different consumption numbers than what PVOutput.org is recording, I wonder what would cause that? For example yesterday, TED shows 90.8kWh while PVOutput shows 93.9kWh.Comment
Changed it to Phoenix, it was setup to Australia...but the information didn't change, still shows 93.8kWh...maybe it takes some time to update?Comment
My TED 5000 does the same thing although the difference is typically less than 5 kWh/day. After several months of kWh usage/production, I calibrated my MTUs to show similar kWh usage/production as my POCO bill -so for instance, I found if I calibrate my usage MTUs to 102% (1.02) and calibrate my production MTU to 101% (1.01), I come relatively close to my monthly bill(with variance of when the readings occured). Since I check PVOutput daily, I adjust the production/usage and peak output/time in the morning for the previous day(typically less than 5 kWh) anyway.Comment
I notice that you're showing PVOutput on the table. Does that mean that your system is already up and running? That was pretty fast.Comment
I wish. Not even anywhere close...as in, the permiting stuff isn't even ready to submit.
The PVOutput data is from my TED unit and it shows energy consumption (vs generation from a PV system).Comment
