what are the pros & cons of running the conduit through the attic vs on the roof? i have a 2 story house and the panels will be on the back, so the conduit won't be really visible on the roof anyway... thanks
Most Popular Topics
conduit from panels to inverter through attic or on roof?
I'd run the condouit around the eves, or the side of the roof, and come back UP to a sheltered spot under the eves and then penatrate into the house. I don't like exposed holes. Roof putty only lasts so long before it leaks.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
You can also use what is called a solar deck.
can be mounted under a module very clean installNABCEP certified Technical Sales Professional
As an installer, on a typical pitched asphalt shingled roof, I think it is almost always best to go through the attic if possible. The aforementioned Soladeck is a great product for such applications. Running conduit on a roof is ugly, and creates it's own problems of attachment points (more roof penetrations? do you flash? etc), and issues with raceways with direct exposure to sunlight [310.15(B)(3)(c)]. One local company commonly uses carflex to run down a roof, and jump over/bend around the gutters, then down the wall. It's way ugly. That said, my aesthetical preference may not be universal. Both ways can be done legally.Comment
