Anyone know the manual cleaning frequency of residential Panels? Any pointers to data re: loss of energy through dirt & debris accumulation? I am new to this forum stuff and welcome all input. Many thanks!
Most Popular Topics
Solar Panel cleaning
Just hose them down when they get dusty or dirty. Not much to it as any kid with a garden hose can do it.MSEE, PE -
Thanks Dereck. We are a building Maintenance Co & figured we have the infrastructure why not offer cleaning? There are companies with cleaning solutions, cleaning kits etc why not offfer the service?Comment
PV cleaning should only be done at dawn, or dusk. Sloshing water on panels that have been toasting in the sun, induces un-needed thermal stress. The dark blue cells, heat the panels hotter than a car windshield, and those crack all too often from thermal shock.(Rain is often preceded by clouds, allowing the panel to cool).
I wash mine about 4 months after the last appreciable rain. Never see much gain afterwards. Water is the only recommended thing to use on them, I do mine in the AM, when the dew has softened the grunge overnight.
A DI water rinse would be a good thing, to keep mineral spots off.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Hi Mike, interesting posts, thanks. How long have you had solar panels. In Australia some companies only offer 10 year warranty. Any comments?
cheersComment
4 Months after that last rain! Fortunately I live where that isn't even a possibility. However, my metal roof, only two years old, has a visible layer of grunge on it, thin layer of dirt. I'm sure that any array will need a cleaning, rain or no. I'm thinking of getting one of those soapy washer things that hook up to the hose. I'll definitely be on a safety rope when I'm standing on the slick metal roof slinging soap.PV cleaning should only be done at dawn, or dusk. Sloshing water on panels that have been toasting in the sun, induces un-needed thermal stress. The dark blue cells, heat the panels hotter than a car windshield, and those crack all too often from thermal shock.(Rain is often preceded by clouds, allowing the panel to cool).
My roof is 4:12 (19 degrees) and I plan to mount the array flat to the roof. Steeper arrays will need less cleaning. I have a friend who'
se had an array since 1986, at 38 degrees, and has never cleaned it. Don't know how much capacity he's lost, but it still works OK.
--LawrenceLawrence Lile, PEComment
I'd go easy on the soap, as residues often attract and cement more grunge each cycle. A carwash kit (Mr Clean) that has a DI rinse cartrige would be a better investment instead of soap, I think.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
