I'm evaluating options for a Grid-Tie PV system in SoCal, and would appreciate any advice the group has:
Situation: I have a south-facing roof with excellent sunlight, about large enough to hold a 7-8kW system. There's a chimney in the middle of the roof, which creates some shade, but otherwise, it's an excellent location. I also have a secondary roof section that could hold another 2-3 kW with similar facing but an older roof and small shading concerns from a nearby tree, which could be regularly trimmed back.
My options are a 7.8kW Sunpower system squeezed onto the main roof at $40,500 Gross ($5.15/watt), or a 8.8kW Solarworld/REC (I have two similar bids) system on both roofs at $38,750 Gross ($4.27/watt).
Both systems project production between 13-14k kWh annually (depending on assumptions). I expect some increase in usage as my kids get older, and if I add more EV miles.
Questions:
1) How hard is expansion of a system? Given my unknown future usage, should I leave panels off of the older secondary section, and hold that space open for a future expansion when the roof is eventually replaced?
2) The vendors I have are quoting different sizes of inverters. The 7.8kW Sunpower is quoting an Inverter with a 7680 kW Output, while the 8.8kW Solarworld/REC quotes are split between the same 7680kW Output Inverter, and a 6.6 kW Output Inverter. Is there an advantage to having a larger inverter relative to the panel input? What about expansion? Were I to add a second bank of SunPower on the secondary roof in 5 years, am I going to want a new inverter for that bank anyways, or would I normally just use the available headroom on the existing inverter?
3) The general consensus seems to be that while Sunpower is a higher-quality and higher-performing product than the competition, that in most cases where space is not a constraint, it's not worth paying for sunpower compared to installing more panels of a lower-performing product. Based on my situation above, and the price difference of $0.90/watt, is Sunpower worth it?
4) The REC/Solarworld quote is using a single inverter. For an installation with limited shade, should I be asking about microinverters?
5) Despite the difference in size, all the bids project the same rough amount of solar generation. Is that accurate? Will I get the same solar production from a 7.8kW Sunpower system as a 8.8kW Solarworld/REC system, or are they just using projections with more or less conservative assumptions?
Questions:
