How big a factor is cold weather when choosing panels?
Most Popular Topics
Cold weather and Panels.
Not so much in just the panels. It matters more in matching the panels and charge controller together. You don't what the VOC of the panels(string) to rasie above the limit of the charge controller.
WWW -
Cold weather causes the panels to produce slightly higher voltage. When you connect several panels in series, you have to make sure the cold weather voltage does not exceed the controllers input limit. and then you have to check that the hot voltage is still enough voltage to charge batteries (heat reduces voltage slightly)Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
