  • BilljustBill
    • Aug 2009
    • 118
    Panel labeled with "Pmax" on amp and voltage?
    On the rear panel sticker are terms and numbers. What does "Pmax" 5.71 and Pmax 17v. mean?
    If a panel is measured with a multimeter and shows 20.3 v, and 4.02 amp under a multimeter load in clear 2:00pm December skies, and is rated for 100 watts, +-3%, any ideas as to why it's not kicking out 100 watts?
    Thank you for your help,
    Bill
  • Jason
    Administrator
    • Dec 2008
    • 990
    Hi Bill,
    VMP = voltage at maximum output
    IMP = amperage at maximum output.
    Voltage at Pmax (vmp) and Current at Pmax (imp) are the optimal measurements drawn from the solar panel.
    17*5.71= 97.01W
    So 97W is the Nominal Power of the panel
      There can only be on Pmax for a panel. Power Max.
      That only happens at a specific voltage. Useally a couple volts below Open Circuit voltage.
      Short Ckt amps is only for testing. To read true power, you have to have an electronic load box, that provides a load for the panel, at say 17Volts, and then you can measaure your Max power. A 12V battery will alwsys pull a panel below it's MAX rating , down to about 13V
      • BilljustBill
        • Aug 2009
        • 118
        Here is the rear Spec sticker with data.
        Bill
