Hello, last year I have found in the street a free Suntech STP180S - 24/Ad 180watt solar panel with the glass broken (after a big icy storm in my region).
Open - Circuit Voltage (Voc) 44.8V
Optimum Operating Voltage (Vmp) 36.0V
Short - Circuit Current (Isc) 5.29A
Optimum Operating Current (Imp) 5A
Maximum Power at STC (Pmax) 180Wp
Operating Temperature -40C to +85C
Maximum System Voltage 1000V DC
Maximum Series Fuse Rating 15A
Power Tolerance +/- 3%
Solar Cell Mono-crystalline 125×125mm
No. of Cells 72 (6×12)
Dimensions 1580×808×35mm
Weight 15.5kg
Front Glass 3.2 mm tempered glass
Frame Anodized aluminium alloy
Junction box IP67 rated
Output cables H+S RADOX SMART cable 4.0mm2, RADOX SOLAR integrated twist locking connectors or MC4 connectors
Nominal Operating Cell Temperature 45C +/- 2C
Temperature coefficient of Pmax -0.48 %/C
Temperature coefficient of Voc -0.34 %/C
Temperature coefficient of Isc 0.037 %/ C
I want to make a solar installation with this one, because I don't need a lot of energy (led lighting, low power consumption computer, and solar shower).
I've just bought a CMP12 Charge Controler.
Color: Black
Type: 101 (10A, 12/24V) CMP12
Rated Voltage: 12V/24V
Rated Charge Current: 10A
Rated Load Current: 10A
Working Temperature: -20 to 60℃
Voltage Of Stop Power Supply: 10.8V or 21.6V
Voltage Of Resume Power Supply: 11.8V or 23.6V
Voltage Of Stop Charging: 14V or 28V
Temperature Coefficient Of Voltage Stop Charge: -3mV/°/C/cell
Size: 101(L) x 95(W) x 35(H)mm
Net Weight: 162g
Adaptive three-stage charging mode
Charge your battery with auto charging mode to avoide power supply fault, ensure effective and full capacity charging result
Prevent the capacity of your battery from attenuation aging
Over-load protection
Short circuit protection
Under-voltage protection
Over-charging protection
Protection from the lightning strike
My aunt gave me her car battery it's a quite new 12 volt 50ah one.
I wonder what can I use to regulate the voltage coming from the solar panel (it still gave 80 watt in full charge... but strangely it have broken my voltmeter after mesurate it 5-6 times).
I wonder where I can find a stuff which take 10-36 volt (5 amp) and transform it in 12 volt 10 amp before plug it to my cheap charge controler.
I've seen on ebay a "120W-GOLF-CART-Voltage-Reducer-Converter-Regulator-36V-To-12V-10A-36-volt-10amp", would it be OK ?
I am totaly newbie in solar panel technology and I am not very rich.
Weight 15.5kg
Color: Black
Net Weight: 162g
