Poly vs mono and SMA vs Enphase
Your search for a difference over a short term does seem silly though. With no shade there is very little difference outside of sales pitches.[SIGPIC][/SIGPIC]Comment
I do like your data and it is meaningful however, clouds (not clowns...) differ on different days.
When it's cloudy out in PA here, my system is producing from 10% to 40% of the nameplate rating.
When it is sunny, I'm seeing nameplate+ during the peak sun hours of 11am-1pm. Cloudy days in PA seem to outnumber sunny days this year.
If a certain module types or inverters work better when the majority of days is cloudy, then they may benefit those in cloudy climates and customers can choose accordingly. Do you have poly modules on one and mono on the other? What exact modules do you have and that would make for interesting reading to see what the details are of each system.PowerOne 3.6 x 2, 32 SolarWorld 255W monoComment
What I am trying to gain is whether on cloudy days where it's not optimal sun and lots of shades, how well the micro perform over the string. So far, I've seen that micro does in fact perform better. To exclude random cloud formation (even within 5 miles), I will have to average all the cloudy days. I think if I average out all cloudy days (basically any days where the string is producing less than 30 kwhr), I can come to some sort of conclusion. A 1 kwhr swing can be chalked up to random variations. However, if I see swings of 2 or more kwhr, it can be safely inferred that micros are superior when there are shade issues. Shade issues aren't always due to trees but clouds as well. For those living in non-sunny states, this could be a factor in their decisions.Comment
Heat is a huge factor with micros where I see it losing up to 10% output if the ambient temperature reaches 90 degrees or more.Comment
The panel output goes down with temperature - the inverters should not be affected.[SIGPIC][/SIGPIC]Comment
I'm not sure if this is totally true. The microinverters efficiency does go down as temperature go up. At any one time, each of my panels differ in AC production from 0-10 kw (higher differences on hotter days). It's not rare to see two of my inside panels produce 197 kw while the ones on the outside edge produce 210 kw. Checking the temperature, the outside micro inverters are always 10-15 degrees lower. It also consistently outproduces the inside panels. The ones with the lowest production at any snapshot in time also has the highest internal micro temperature as well. I believe temperature affects both panel and inverters efficiencies.Comment
I think that can explain the entire output difference you are seeing. Remember that the outside panels will be cooler than the inside panels, just as the outside inverters are cooler than the inside inverters.
The most likely effect of temperature on the microinverter with a constant input (like a temperature controlled panel) would be that as the inverter gets too hot its protective circuitry reduces its output. The efficiency may not change noticeably because it will just take less input power from the panel. But it would not be doing as good a job of getting all possible power from the panel.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Panels - yes and the panel spec includes the information[SIGPIC][/SIGPIC]Comment
The ambient temperature of the inverter. The hotter your inverter gets the lower its efficiency will fall. Which is why it should always be installed in a shaded, well ventilated location.
As a general rule, colder is better for efficiency. Most materials and components become more resistive as they get hotter. However, there may be a practical limit for how cold the system can reasonably function. Most electrical components are rated either to 0C or -40C as a minimum ambient operating temp.Comment
This is what I mentioned about how the output may be limited, even though the efficiency does not change. It may not be a factor for inverters designed for outside roof mounting like micro inverters:
In order to keep the heat low, the inverter will stop generating power or reduce the amount of power it generates by “derating” as it passes programmed temperature milestones. Figure 1, below, from SMA, shows how an SMA inverter handles temperature derating. At about 45 degrees C. it starts to ramp down power.
Context: "The two minor factors are:"
Also minor and very generalized:
As a general rule, colder is better for efficiency. Most materials and components become more resistive as they get hotter. However, there may be a practical limit for how cold the system can reasonably function. Most electrical components are rated either to 0C or -40C as a minimum ambient operating temp.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Has anyone ever measured the temp on the back side of the panels where the microinverters are mounted?
I have done so with solar thermal panels but not PV panels.[SIGPIC][/SIGPIC]Comment
