Hi folks
I've got an overland campervan which I'm currently driving around Africa. I recently found my electrical system has some severe shortcomings, and since I'm in the middle of deepest darkest Africa, I'm having to try sort things out myself.
I have 3 x 100Ah deep-cycle batteries, 2 x 60W panels and a Steca PR 2020 solar regulator. The Steca solar regulator uses PWM control to achieve multi-stage charging, resulting in optimum battery charging. However, at peak solation, I'm only getting about 7.5A from the panels, and often I'm taking more than that out.
Now I've also got a 15A DC/DC converter which runs off my truck's alternator, converts 24V to 12V, and connects the 12V output straight to the deep-cycle batteries. It works, up to a point, but won't be able to charge the batteries fully (apparently it will only achieve about 50% charging). I'd like to take advantage of the solar regulator's 'smart' charging system to fully charge my batteries when driving.
My solar regulator is rated up to 20A.
My panels produce maximum 8A.
My DC/DC converter produces maximum 15A.
What I've tried to do is connect the solar panels to the solar regulator when I'm parked up, and then when the truck is running, disconnect the panels and connect the DC/DC converter in their place.
I've done this successfully with a relay, but when I look at the solar regulator's display for the amount of current being produced by the "panels" (aka: the DC/DC converter), and the amount of current being sent to the batteries, both read 0.0.
Now the only determinable difference I can see is that the panels produce in the order of 16V, while the DC/DC converter is producing about 13.5V. From what I can see in the regulator's specs it says Open circuit voltage solar module: <47V. The operating instructions say [I]Voltage range 12V: 6.9 V
