Hi. I just replaced my solar inverter with a (hybrid inverter + battery) pack. It comes with backup functionality so I naturally connected my house most critical circuits to the inverter's backup port. The functionality works great - I turned off grid supply to the house and the backup loads did not even notice. But then, to my big surprise, I found out that if the inverter is malfunctioning or rebooting or updating firmware, it will stop supplying power to the backup loads. With this setup my critical circuits will survive the blackout but will lose power if something goes wrong with the inverter. Considering that last blackout here was more than 10 years ago, I'm much more likely to lose power due to the inverter malfunction than a blackout. Eventually I flicked the changeover switch (which was part of the installation) to move my backup circuits to the grid supply.
My question is - do all inverters work this way? My expectation was that the backup port has a hard connection to the grid inside the inverter, so even if the inverter is completely shut off, the current would still flow from the grid to backup loads. And if the inverter operates normally and detects the grid outage, then it would switch backup port to the battery.
