MPP Solar inverter MPI 5kw PLUS problems and putting
  • tkmbe
    • Nov 2020
    • 3
    Hello
    Anyone using MPP Solar inverter and specific the MPI 5kw PLUS?
    I've several problems with this inverter and a Battery Pack.
    I think the FW is bad and MPP solar does not respond.
    I have debuged that the batteries are not charged with the max voltage is there is no sun
    from the grid and so after storms and battery pack empty they will load badly and suldate
    the batteries.
    i want to change my AGM batteries 4x275Ah Ultracell UCG275-12 for Litio
    but I have to know if I can connect it to my inverter...
    I read womthing about Pylontech batteries and a RS485 interface which you have to buy apart...
    Any information would be nice
    Starts
    05-28-2025
    Ends
    05-28-2025
  • SOUOPower
    • May 2025
    • 3
    When using the MPP solar inverter MPI 5kw PLUS, if you suspect that the firmware is damaged, you can restart the inverter first, or go to the official website to download the latest firmware and update it with USB; if the battery charging is abnormal, you need to check whether the inverter charging parameter settings match the battery type. If the settings are correct, it may be a hardware failure. It is recommended to find a professional for repair. When replacing the AGM battery with a lithium battery, you need to confirm that the inverter and the lithium battery voltage, charge and discharge current match. When connecting, disconnect the power load first, connect the positive and negative poles correctly, and check carefully after connection. Test the operation from a small power load first.
    Mod edit: No ad links or links to products until you've been here awhile, thanks.
    • tkmbe
      • Nov 2020
      • 3
      Thanks for answer
      But I have never found on the MPP Solar page to download a fw.
      Do you have any link?
      The parameters are right configured.
      The problem is that the battery are not loaded with bulk parameter if there is charged from grid not solar and this is wrong....
