Found some 4AWG in my vehicle! - Use it for my control board?
  • Richiep
    • Sep 2017
    • 28
    Hey All,
    I'm slowly putting together my "control board" which will house the main components of the system; charge controller, inverter, battery hookup and solar hookup... It's hard to say what the system will "become" but right now I'm building around my MPPT controller which is a SolarEpic Tracer4215BN which allows for 40A in and 20A out. I'm designing a 24V 1.2Kw array and battery bank. Based on my reading on wire sizing so far, it sounds like it's hard to, if not impossible to use wire that is too thick. Is this true?
    I recently bought a used vehicle that had a hard wired inverter run from the battery. I don't have a need for it so I pulled it out and with it came about 12ft of stranded 4AWG wire. The wire is in good shape so I'm considering using it to tie together my components. Based on some number crunching I could get away with 8AWG for this system so I'd be oversizing the wire a bit here. My gut feeling says this is cool but I don't know for sure.
    Are there any pitfalls for using oversized wire?
    Side question.
    When connecting this wire to the charge controller do I just stuff the raw stranded wire in the screw terminal? Seems dangerous. Tin the end? Or is there some kind of end crimp on end connector for this kind of application?
    Thanks!
    Rich
    12V 12W panel, SolarEpic Tracer4215BN, 12V 18Ah
  • Richiep
    • Sep 2017
    • 28
    I've been continuing my research and found this guy who does a bang up job of explaining how to size and purchase the right wire.
      Side question.
      Thanks!
      Rich
      Well, you've run into one pitfall... if the wire is thicker than the terminal can handle. I'm a fan of using ferrules to tame stranded wire (with a hexagonal crimping tool), but some types of terminals handle stranded better than others. If the terminal is only rated to accept smaller wire, it is proper to use a split bolt connector (or something like it) to transition from the heavier wire to something lighter than can be accepted by the terminal. Please don't just cut off strands to make it fit.
      Another related pitfall is that bigger wire takes more crimping force to terminate properly. 4 awg isn't too bad, but the bigger you go, the more difficult it will be to crimp properly.
        https://www.youtube.com/watch?v=p1bnHu14SMs
        And he is totally (criminally) wrong about terminating the wires. Beware of youtube idiots
        • littleharbor
          • Jan 2016
          • 1998
          Probably the worst example if terminating cables out there. You could (literally) do a better job with a rock. I'm surprised this video has been allowed to remain on Youtube. At least the comments pretty much all, call this guy out on his bad advice.
          • Richiep
            • Sep 2017
            • 28
            I'm a noob over here so please point me in the right direction. I see they make a crimper that you bash with a hammer to install the crimp, $20
            Thanks!!!
              Wow, that's pretty bad. Haven't seen the "put the terminal in a vise" thing in years.
                • 15045
                U-tube == The new idiot's bible.
                  To really, properly crimp cables larger then 6ga, you need a hydraulic crimper in the 6-15 ton range. The idea is not to simply deform the lug so it sticks to the wires, but to apply enough pressure with a 6 sided die, to fuse the copper strands to the tinplated copper shell and make it all gas tight. Can't do that with a "hammer/anvil" crimper.
                  You don't want a plain copper lug, tin plate is required for UL as it keeps the copper from oxidizing.
                  Soldering causes the solder to wick along the wire, making it stiff, and concentrates all bending forces at the end of the solder, usually causing a break in the cable in a couple months.
                  Solder can also melt and the connection falls apart in an overcurrent situation,
                  • max2k
                    • 819
                    Thanks!!!
                    bad connection especially on the thick wire (large current) is sure way to start fire, please listen to advice given here, $20 won't cut it.
