Hi,
New to the forum, I joined because Im having trouble finding the inverter I want.
I want to do a residential hybrid system with these requirements:
3-4 KW (3 kw of PV panels)
240 AC output
24-30 volt DC battery input (for lithium 28v)
User programmable control of charging set points (because of lithium)
UL 1741 listed for grid intertie
There are Taiwan and China models (MPP solar, Ginlong, etc) that I would absolutely go for but they are not UL listed, so my power company wont allow grid tie. These range from about $500-1200. Lots of people using them in other countries with good reviews.
SMA sunny island is a candidate but its over $3000
Outback makes 120v models, so I would need two, again over $3000
That kinda kills the project if I have to spend over $3k just on the inverter.
Im also exploring the possibilty that I may have to do it with two inverters, one off grid and one grid tied. I would rather not if possible. I want to keep it as simple as possible. Many grid tie only inverters want high DC input voltage, and off grid inverters seem to want lower DC volts.
I cant be the only one who has done this, why are there so few inverters with these specs?
Any recommendations?
BTW, the main reason for 240v requirement is I want my well pump available during grid outage. All other critical loads are 120v.
240 AC output
