Has anyone heard of this? Apparently it's some kind of battery backup system. I wonder if it will somehow allow a system similar to the powerwall with other inverters
Solarmax Flex
It sounds like a new energy storage system being advertised. It still comes down to the cost / kWh over the life time of that system compared to the cost of using the grid or a small generator as a backup power source.
5kWh is pretty small potatoes for most home electrical loads and will easily be used in less than 8 hours that they advertise. -
We also do something similar with Li batterys, capacity is 3KW. You just plug in your PV connection then you could power all your home applications.Comment
As opposed to most solar installations where the customer has to climb up onto the roof and haul the panels up himself?
