I tried looking all over the internet for an answer on the power flow in DC-coupled grid-tie systems with battery back-up. All sources claim that if PV production > load then the surplus will go to charge the battery. I'd like to know why it is like that and not the opposite, meaning why isn't the battery primarily fed and the surplus sent to the loads.
Power flow in solar hybrid system
The CC will normally send all the power it can get to the battery as long as the battery can accept that current.
If some of the current goes to a load (DC load or via inverter), most CCs will not be able to tell whether it is going to the battery or a load or some combination.
Once the CC output it at maximum, and additional loads will end up drawing current from the battery.
If you have a more sophisticated CC it will be able to tell via a shunt what the actual battery current it, but it will still not have any way to tell the current to go one way or the other.
When the the CC is integrated into a hybrid inverter, then it does have the capability to control the loads more directly, but it still cannot control how much goes to the battery and how much goes to the load.
If the panel output is greater than the total non-charging load, the extra current will go into the battery. The only way to preferentially charge the battery requires the ability to actually shut down some or all loads. Most systems do not have that functionality.SunnyBoy 3000 US, 18 BP Solar 175B panels. -
From what I understand, the charge controller comes directly after the PV array and is not considered a load, but rather the batteries are. The CC basically just dictates the voltage at which the batteries should be set depending on their state of charge. I think it does matter how the power flows in that system since according to most sources, PV primarily feeds the loads and any excess is used to recharge the batteries. What I'd like to know is how they came up with that statement. Could it be something between the CC and the Inverter or maybe something related to basic electric circuits theory that I must have missed?
The real answer is that it does not matter. The electricity will divide by the voltages and resistances involved and where the loads are, including the battery charger as just another load.
If the panel output is greater than the total non-charging load, the extra current will go into the battery. The only way to preferentially charge the battery requires the ability to actually shut down some or all loads. Most systems do not have that functionality.Comment
From what I understand, the charge controller comes directly after the PV array and is not considered a load, but rather the batteries are. The CC basically just dictates the voltage at which the batteries should be set depending on their state of charge. I think it does matter how the power flows in that system since according to most sources, PV primarily feeds the loads and any excess is used to recharge the batteries. What I'd like to know is how they came up with that statement.Comment
I tried looking all over the internet for an answer on the power flow in DC-coupled grid-tie systems with battery back-up. All sources claim that if PV production > load then the surplus will go to charge the battery. I'd like to know why it is like that and not the opposite, meaning why isn't the battery primarily fed and the surplus sent to the loads.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
This is getting confusing. Most online sources say that the solar panels give priority to feeding the loads and use any surplus to charge the batteries. If the batteries are full, the surplus is fed to the grid. That's how I understand it at least. The question is how is that topology assured?Comment
This is getting confusing. Most online sources say that the solar panels give priority to feeding the loads and use any surplus to charge the batteries. If the batteries are full, the surplus is fed to the grid. That's how I understand it at least. The question is how is that topology assured?OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Do you have any documentation that supports that?
There is a DC Bus. the Charge controller, batteries, and inverter are on that bus. In a smart monitored system the sensor determine the state of charge and the charge controller drives the voltage up to a charge level or whatever level is required. The inverter is turned on to draw what excess is available off. There is nothing manually switchingComment
The charge controller provides a voltage, backed up by the current it can produce from the array. If more current than that is drawn from the controller than the array can support, the voltage droops. This reduces charging to the battery, or causes a discharge from the battery.
The battery itself is basically a voltage source, with the voltage set by the state of charge. The battery's chemistry determines what the relationship between voltage and state of charge is, and also what the equivalent resistance is.
Additional DC loads can be attached to the battery. The loads draw power from the system. Since the charge controller is a "stiffer" voltage source than the battery, it supplies most or all of the current due to Ohm's Law.
Some inverters will sell extra power to the grid. They do this by setting a voltage level. If the system voltage goes over this level, it is assumed that the battery is adequately charged, and the additional current (that would ordinarily go towards pushing the system voltage up and/or being unused) is used to run the inverter to feed the grid.
A lot of people get confused because they don't see the "switch" that "decides" to send power to the battery or the loads. That's not how it works. The routing of current happens entirely autonomously, based on Ohm's Law.Comment
MSEE, PEComment
supports what? that there is a DC bus that everything is attached to?
that everything is controlled by the computer (in outback called Mate3)?
try the documentation:
OutBack Power, headquartered in Bellingham, Washington and is the leading designer and manufacturer of advanced power electronics for renewable energy, back-up power and mobile applications. The Company is also a member of The Alpha Technologies -- a global alliance of companies that share a common philosophy: create world-class powering solutions for communication, commercial, industrial and renewable energy markets.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Thank you that's very helpful. I was not looking for that switch though i just wanted to understand how it happens and according to you it's all ohm's law. One more thing: you do confirm that dc loads and/or the inverter are primarily fed by the array and the surplus charges thr batteries?
Physics and chemistry.
The inverter is "smart" - it will draw as much current as it needs to satisfy its loads. In other words, if it is generating X watts at 120 volts, it might draw 10 amps at 14 volts on the DC side. If the voltage drops it will draw more current. If voltage drops to 10 volts, for example, it would then draw ~14 amps to support the same load.
Batteries have the opposite behavior. If a battery is taking 10 amps at 14 volts, as the voltage drops so will the charge current. At 13 volts it might take 2 amps. At 12 volts it might take nothing. At 10 volts it is going to be _sourcing_ power back to the loads.
So as the load on the inverter increases, the inverter will take more and more power and will pull the voltage down. The battery will take less and less power as the voltage drops, and at some point might even be _sourcing_ power.
That's also the reason that off grid systems almost always need batteries, so that the transient changes in AC loads don't pull the DC voltage down too far. The battery keeps the voltage within a reasonable range, which makes it easier to operate the inverter and the rest of the system. (And of course provides power for times of no sun.)Comment
Fair enough but this is the behavior of an inverter acting as a voltage source and not a current source as the grid tied is supposed to act. Does this mean that the hybrid inverter acts as a voltage source even when the inverter is grid tied?
That's the effect, although the cause isn't as deterministic as that.
