Greetings everyone, this is my first solar installation. Im am excited to finally be working with solar and lucky to be doing it on a very nice location oceanfront. (Pics to follow) A little background, I'm a residential builder from California working in the Philippines islands for the past 2 years.
I have spec'd out most of my hardware and received the OutBack inverter already.
My questions are more specifically:
1. Are my number of batteries to solar panels are correct? Should i be able to fully charge the 32 batteries every day and continue to run the residence requirements of 12-16 kwh per day?
2. How best to layout the strings of solar panels, they will be ground mounted on cement slab so its flexible on the space side. There are very high winds at the location to consider as it is ocean front I want to keep the panels low to the ground. (Multiple rows)
3. How to most efficiently wire the Charge controllers, which strings goto which charge controller or just 14 panels to each flex80 to make it even 14x2, as i understand they have 4000 watt capacity each. My length from flex80's = 35 meters.
--Here are my system specs on the project to run by everyone and hopefully get some feedback I really appreciate the input here--
Grid (Stable at 220V - 60HZ Single Phase)
Notes: Outages frequent couple times a week for a couple hours, during bad weather long outages lasting days.
Inverter ( Outback GS7048E ) 240V - 60HZ Single Phase
Input 1 - GRID
Input 2 - Honda EU6500IS Inverter Generator LPG Fuel source
Outback GS Load Center
MATE3 Controller
Charge Controller 1 - Flexmax/80
Charge Controller 2 - Flexmax/80
28 MODULES
PV - SOLARWORLD (Solar Cell Germany, Monocrystalline)
Max Power Voltage Pmax - 250 Watts
Max Power Voltage VMP - 30V
Max Power Current Imp - 8.33A
Short-Circuit Current Isc - 9.99A
Open-Circuit Voltage Voc - 36.6V
32 BATTERIES Running at 48V
12V TROJAN AGM 31
100-Hr Rate - 112AH
Residence Load Schedule
400-500 KWH per month
Basic House loads, No AC
2 Well pumps, Ref, lights
Thanks !
Lou
Input 1 - GRID
MATE3 Controller
28 MODULES
12V TROJAN AGM 31
100-Hr Rate - 112AH
Thanks !
Lou
