New to Solar. Looking for advice
  • diybodger
    • Jun 2025
    Hi, I have been given 2 x 225w Canadian Solar panels and a 120ah Leisure battery. I would like to use them on my shed to charge my cordless batteries. But as I read about Solar on the internet, have become quite confused as to what ratings would be needed and an issue I think I have.
    Firstly, I purchased a cheap MPPT controller off ebay and just rigged the panels up to see if it worked. They did but when it got dark the battery drained. I have read that this could be due to the diodes on the panels are no longer working. Is there a way to test this?
    Secondly, I am thinking I need a 60A controller. Is this correct?
    Thirdly, would a 15A panel isolator be sufficient?
    Finally, what rated inverter would I need to power 3 x 18v cordless battery chargers off a 120ah lead acid battery?
    Lots of questions but hoping I can get some good advice so can move forward or at least, prevent burning down my shed!!!
  • chrisski
    • May 2020
    • 577
    You can read any sticky by SUNKING to get great starting info.
    I would start by disconnecting the panels after they charge and see if the same thing happens. I suspect a weak battery. If its that weak the battery wil drain without the panels.Can you check the diode with a multimeter? Short in one direction; open in the other.
    Need to know more about the battery charger. For my usage with M18 Milwaukee rechargeable batteries with a single charging port, 140 watts of power is plenty, and I carge so infrequently, a 10 amp MPPT would be sufficient.
    I’m unfamiliar with a panel isolator.
    This is the key to the whole project. I recommend getting a kilawatt meter and get accurate data by plugging the charger into the wall to see how much power this thing pulls on 3 empty batteries
    Looking for:
    1) Max Watts
    2). Total kWh for the day.
    There’s a bit more math involved for the build.
      • 15202
      Just to let you know most good MPPT controllers are not "cheap" and ebay is not always to best place to purchase chargers
