on grid inverter to hybrid solar
  • jackson
    • Mar 2016
    • 6
    good evening, pls i need assistant with calculation on what to use for my solar set up.
    am using inverter before but i wish to convert to solar, i used 4bedrooms,
    d load i normally use is as follows:
    4 * FANS
    2 * TV
    5 * 7 BULBS (18WATT EACH)
    1 * FRIDGE
    4 * 12V/200AH BATTERY
    3.5 KVA 48V INVERTER
    Wish to increase d battery to 8 (12V/200AH), Also to get 5KVA INVERTER.
    Pls how many solar panel will i need to get and it capacity?
    what other thing ll i need to get also?
    sun do shine for average of 7 hours here.
    thanks
    • 15179
    Hello jackson and welcome to Solar Panel Talk
    I am sure someone will be able to help you but first you need to provide more information concerning your electrical loads.
    Fans - how many watts do they use and how long will they run a day?
    TV - how many watts do they use and how long will they run a day?
    Bulbs - 18 watt each. How long will they be on a day?
    Fridge - how many watts do they use and how long will they run a day?
    Without that information or at least a really good guess on your daily watt hour usage it will be hard to tell what size battery system is needed and how many panel watts you need. That is also dependent on where you live and what your lowest insolation hours you get all year round.
    • jackson
      • Mar 2016
      • 6
      Thanks Moderator,
      FAN 60W FOR 14HRS PER DAY * 4
      TV 150W FOR 14HR PER DAY * 2
      BULBS 10HRS PER DAY * 7
      FRIDGE 170W 24HOURS * 1
      WASHING MACHINE 500W 2HRS TOP
      PRESSING IRON 1200W 1HR TOP
      Thanks!
        Originally posted by jackson
        Thanks Moderator,
        Thanks!
        That is a very heavy load!
        I hope that most of the biggies, like the pressing iron and the fridge actually cycle on and off and us less energy.
        Using a watt-hour meter would be very helpful.
          moving into these large loads, I'd recommend that you go to a 48V battery system. Less amps in the wires, still the same watt-hour capacity.
          • jackson
            • Mar 2016
            • 6
            Good morning!
            Thanks for ur comments, a friends sent me some solar stuff but am left with d combinations, i ve calculated my consumption per day
            MY DAILY CONSUMPTION IS 10,000WH
            PV 250W * 12
            BATTERY 12V,200AH * 12
            INVERTER 3.5KV,48V
            SOLAR CHARGE CONTROLLER 12V,24V,48V. 60A. 96VOM
            can i connect 6 PV in parallel in two places ,then join them in series? also batteries, 4 in series in three places and join them together in parallel? how long will it take to fully charge d batteries and will d charger and battery be ok for my consumption.
            thanks!
              You do know any power from the batteries is going to cost you a whole lot more than the utility charges you? That means you wil be paying a lot more for electricity. Is that what you want?
              There is no way the batteries you mention is capable of supplying your loads. At 10 Kwh per day would need to be 48 volt 1050 AH weighing some 3000 pounds and costing you $10,000 today, and even more in few years when you replace them.
              • jackson
                • Mar 2016
                • 6
                Pls, how many of the mentioned battery i ll need 4 back up? can 12 PV powered d batteries? also d solar controller ( MPPT) be compartable? note: average sunlight is 7 hours per day.
                Thanks!
                • jackson
                  • Mar 2016
                  • 6
                  Evening!
                  Pls i need help with this:
                  How long will it take 12 pv of 250w to fully charge 8 batteries of 12v,2ooah. Considering 5 hrs of sunshine during the season.
                    You have 3000 watts of solar. You have 19200 watt-hours of battery.
                    If the batteries are completely dead (unlikely) then you will take ~7 hours ideally. In a more realistic scenario (getting 75% of rated power from the panels) it will take ~9 hours. That's 2 days in a location that has 5 hours/day of equivalent full sun.
                      Evening!
                      There is no help for you. It will not work. You are asking for the impossible.
