Hi, I am a new poster on this forum. I got the urge to build some panels and power outside led lights on my property, so I started building the panels with cells and materials from ebay. I know it is totally not cost-justified, but it is a little hobby that I am doing in my retirement. That said, here is my current situation and what I am trying to figure out:
I have 10 60w panels which produce about 31 amps at peak sunlight. In the morning here it is always overcast and the panels put out about 8 amps for a couple of hours, then it goes up depending on how sunny it gets. I have 480 amp hours (theoretical max) in battery storage. I have 4 different light circuits, which are all independently controlled with light switches, so I can run 1 to 4 of these circuits each night. The total amp draw of all 4 circuits is 7.5 amps. I run the lights from 9 pm to 6 am, 9 hours. My math tells me 9 X 7.5 = 67.5 amp hours of draw. The problem is that the batteries can not charge that much in one day. I have watched and monitored my system carefully and once the batteries are charged up to a certain point, the charger begins cycling and limiting the voltage delivered to prevent over charging. The result is that the most amp hours that my amperage monitor shows delivered by the charger in one day is 50 - 55 amp hours. The batteries never get back up to 100%. So, I run fewer circuits-1 or 2, depending on where the specific gravity in the batteries is before I turn on the lights.
What do I need? More panels, or more batteries, or both?
