I started this educational journey with one slightly damage 250 Watt PV panel that still delivers it spec'd 8.0 Isc amps and 27~32 operational (across inverter) volts. For test purposes I chose a cheap 500 Watt Chinese GTI inverter that claims a peak performance factor of 95% or so. I am trying to determine the best way to measure this micro pv system's overall efficiency.
The last time I checked, I measured the Isc current across the GTI DC terminals at 7.08 amps. The volts across the GTI DC terminals was 28.5. Can I assume that the pv power available for use (28.5 v x 7.08 a) is 201.8 watts? (1)
Next I measured the DC current drawn thru the GTI inverter was 4.28 a, or approximately (28.5 v x 4.28 a) 121.98 watts. At this moment my Kill-A-Watt meter was measuring 108.4 AC Watts going into the GFI protected grid. Now if I can measure the GFI's efficiency by calculating AC watts-out divided by the DC watts-in (108.4 w/121.98 w) I get 88.9%? (2)
But is it reasonable to estimate this micro pv system's overall efficiency at GTI's AC watts-out divided by the DC watts-in available at the pv panel (108.4 w / 201.8 w) or 53.7 %? (3)
I have yet to read of an efficiency this low before adding in all the system's environmental derating factors.
I would like to learn where I error, and also how should I calculate this overall efficiency? (4)
Thanks for any comments of suggestions.
