Does anyone have any information on building a solar tracking system for solar panels, any ideas for building my own cheap system welcome
Solar tracking systems
[url]http://solarwater.yolasite.com/[/url] -
There is a company called something like
red rok
red roc
red rock ? solar, that has kits for the electronics of a tracker, I don't know what they do for the mech gear.
Generally, it's better/easier to put up additional panels, than to maintain a tracker. I've seen many trackers, stuck in the wrong spot. Some are in the parking lot of a solar store. Even they, can't keep them running.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks Mike
Thanks mike it seems a simple idea but there does not seem to be anyone out there who has perfected it yet.
Moderator note - forget the links.[url]http://solarwater.yolasite.com/[/url]Comment
You can buy many - costly though.
DIY isn't so easy - at least for an automated system.[SIGPIC][/SIGPIC]Comment
Yeah, I keep hearing that trackers are complex and hard to keep running. Not had much problem with mine in 3 years, though I did try several controllers,
(edited: removed vendor name due to problems with him. YMMV)
I had to pole mount anyway or face cutting a lot of nice shade trees that pretty much eliminate the need for A/C....so pole mount it was. And as long as I was pole mounting, making them track single axis wasn't that much harder.
I welded a pc of 8" wide channel to the top of a 6" pole at 37 degrees ( latitude angle for here ), then mounted a 2" pillow block bearing at each end, with a pc of 2" shaft steel thru the bearings and out a couple inches past the end of the channel. Then welded an "H" frame made of 2" square tubing that pivots east/west. Then mounted Unistrut to the H frame for the panels to mount on. Whole thing is driven by a 36" linear actuator ( like they used on the old C band satellite dishes ). Controller jogs the array east to west all day, then resets to the east at dark.
The newest array, I made a dual axis ( the one on up the hill under construction in this photo). Bit more welding and mechanics, plus one more actuator, but I wanted to see if I could do it. I don't have the north/south tilt actuator wired into a control board, just have it on a toggle switch, and plan to adjust the tilt angle about 4 times a year manually.
that site doesn't work for me, can you double check it please?
your mounts look sweet. i plan to build a tracker next year.
thanks.Comment
Really ? Based on what ?
Including the controller, I've got about 600 bucks each in my trackers. How does that compare to the Sunpower ? My guess is dirt cheap. And if I get virtually the same performance in power increase, which one is "best" ?Comment
Never said sunpower was cheap. Worm drives are more reliable overtime. Worm drives produce all the torque needed to move 400+ pv panels@ 5amps.Comment
And if I HAD 400+ panels to move, I'd certainly be looking at something like that.
Would you also recommend I buy an ocean liner to fish in a 2 acre pond ? Or would a small Jonboat be "better" ?
To buy one to move a 10 panel array I can move with one finger ( all about balance ) seems like a fool waste of money.
So, clearly, for the money, my homemade systems beat sunpower......as I could replace every moving part on them probably 1/2 dozen times and still be money ahead......and thus, your statement "nothing beats sunpower" is a crock.Comment
TnAndy, have you done any record keeping to see how much power you have gained by tracking?
heck, at one time i had planned on just using an actuator and an old c-band receiver with a timer function to move the array as many times a day as there were program slots. i figure even that would be better than nothing...presuming you modify the program a few times per year. at this time, there are several reasonably priced options for auto tracking, so i am exploring that route now. i do plan to build my own rack and tracking system using an actuator as you have.Comment
defed,
Some......leaving the arrays in the noon position, it appears I pick up about 25% with tracking. I really hate to give up the extra production, so I haven't done it a lot to compare.Comment
