Question on California UL rating requirement for SMA / effective April 1st 2023
I suspect this problem... the Duck Curve... will moderate or go away with EV adoption.
The operative question is how many people can be trained or able to charge during the peak sunlight hours, rather than overnight on baseline load.
What's unfortunate for me is some of these rules apply to retrofits and expansions of existing system. It will result in perfectly good inverters getting thrown away because of regulatory reasons rather than equipment failure or true obsolescence. -
As home solar adoption grows there will times when the grid simply can't absorb all the excess solar power so the PoCo's want to be able to control it. Hawaii is probably the first state having to do this starting a few years ago when they stopped allowing new home solar installation to export excess solar power to grid.Leave a comment:
Lucky that you aren't in the state of CA. Although I see some rough weather coming your way. Stay safe.
I take that to mean, they can choose to shut you down anytime. That
would be quite a disadvantage to the solar owner, since any renewable
energy lost, is lost forever. In addition, who is to say they will not
completely abuse that power. Just check what has been in court in
IL in recent times.
My inverters have no external communication
means, and I have an identical spare set just in case. Bruce RoeLeave a comment:
Good to know that a lot of existing inverters will comply. I just am worried the POCO's and local government may try to use homes as co-generators when the state can't generate enough due to them closing down power stations.
If the new rules make it safer and easier to generate your own power then great but maybe I am just a little worried since the CA POCO's want to keep changing the TOU rules.
Call me cautious.Leave a comment:
IL in recent times.
UL1741SB is not just a California requirement. It is a change in the standards of communication and yes it may give all utilities more control over complying inverters accross the nation. My SolArk already complies with UL1741SBLeave a comment:
Sounds like CA is changing the solar rules to get more control of a homeowners generation by limiting the type of inverter that will now comply.Leave a comment:
That's the one.
This one? UL1741 3rd Edition Supplement SB ?
