Hi there,
I'm new to the whole solar thing so I've been reading and listening to a lot about it lately. Obviously, the amount of information out there is overwhelming, to say the least.
I would really appreciate any help I can get to guide me through the design process of as efficient a 24V system for the batteries (I can afford to start with) as possible.
After doing the rough estimate for my power needs(tv, laptop, lights, sometimes small micro oven/kettle/power tools batteries), taking the price of batteries into consideration as well, I've come to a figure of 2400Wh storage. It's the best I can do at the moment, batteries are expensive.
With that said, I'd go with LifePO4 2x 12v 100Ah in series for a total of 24V 100Ah, roughly a 2400Wh storage.
If I've understood things right, these should be the following steps for me to find out what I need next.
Step 1 - Determining how much solar I'll need.
For a 2400Wh capacity, to get a full charge within 5 hours of direct sunlight, I'll need 480W of solar panels. 2400Wh/5h= 480W of solar.
Step 2 - Finding out which charge controller will do the job for the available solar wattage.
By dividing the solar wattage by the battery voltage I can determine the minimum required charge controller current(A) rating. 480W / 24V = Charge controller of minimum 20A rating, for precaution, should go 25-30A?
Is this correct so far?
I've also heard that in order to pick a good inverter for my system, I'll have to take into consideration the battery C rate in order to pick the maximum inverter wattage. ?
Please, feel free to correct me and share any advice/suggestions you can give me, highly appreciate it! Thanks.
						 The initial 2400Wh will not go to waste, It would just have its dedicated 575W max panel and dedicated charger.
