Maybe I am missing something, but it seems to me, claiming the half cut panels
are much shade tolerant appears to be a gross exaggeration. There may be some
gain if a single cell is covered (I read), but the case here is shade sweeping over a
panel (or array), they will not help at all. Just how are they any better than the 3 in
cells used before we figured out how to make 6 in cells? I see way more conductor
penetrations for connections, more opportunity for moisture penetration. Bruce Roe
So how bad are string inverters vs microinverters?
No scamming on the 120 cell panels. They can be more tolerant of shade and everybody makes them now as opposed to 4 years ago. He's just using today's technology which I think is fair.
I wanted to add a few tigos to my system for shading and calling 5 places it seems no one even understands what I'm taking about . I was wondering if tigo went out of biz. Was it swallowed up by Smi?
about the 120 cell panels, so was he scamming to do that? You think using 60 cell would have been much worse?Leave a comment:
Oh. It is illegal to not have the shutdown feature if your AHJ follows the local and NEC rules. If you don't believe me you can try contacting someone in your area that follows the rules. Just be aware that I will not tolerate someone on this forum that supports breaking the law.
the big advantage of the string inverter was cheaper and simpler, no electronics on the roof. If you need a module at each panel then you killed the string inverter market. In fact if someone wanted to do something like it it is in fact illegal you need what used to be a simple string inverter plus another 29 or 30 electronic breakable doodads on you roof causing problems.Leave a comment:
try these guys
Tigo Energy Solar Inverters | CED GreentechLeave a comment:
Well nomadh if you want to connect to the grid and they follow the 2017 or later NEC you'll need some type of electronic doodad on the roof.Leave a comment:
Actually yes there have been some injuries due to energized solar arrays that fire fighters have tried to remove to save the building that was on fire. So I never said that string inverters are outlawed only that you now need to include "shutdown" equipment to adhere to the latest NEC which all AHJ's read and then determine what it means. So if you don't like what is now the rule then don't perform a DIY install or follow the rules.Leave a comment:
It should be noted that the YouTube author used 120 cell half cut solar panels which can be much more shade tolerant than standard 60 cell panels. That being said, I have an SMA string inverter with TIGO optimizers on 60 cell solar panels and am very satisfied with my set up. I too needed rapid shutdown so why not just get optimizers.
String Inverters rockFrom all the things I've heard for years this really blew my mind.
I can rest easy now with my sma and won't bother to fixate on getting a tigos on that shaded corner.
It should be noted that the YouTube author used 120 cell half cut solar panels which can be much more shade tolerant than standard 60 cell panels. That being said, I have an SMA string inverter with TIGO optimizers on 60 cell solar panels and am very satisfied with my set up. I too needed rapid shutdown so why not just get optimizers.Leave a comment:
Not at all but do need to add an additional piece at each solar module so that the voltage is limited to only what one module puts out. As to a firefighter getting hurt? Whether one has or not the code is being proactive to prevent it. After working 40 years hands on with electricity I can assure you codes are there for a valid reason, getting a rule into the NEC is not something done casually.Leave a comment:
So now we are looking to outlaw string inverters? Has a firefighter ever been electrocuted this way before?
The Fire Departments have found that breaking the roof with a "live" solar array can be dangerous so the NEC has included the requirement of a shut down feature that kills the voltage within a few feet of the panel system.. As long as the voltage is below 50VDC then the First responders shouldn't be electrocuted if they cut into a "live" wire.Leave a comment:
If you don't do the shutdown at the panel level then the wires under the panels can have 300-400 DC volts on them. A mis-swing with an axe while trying to save someone life or property venting the roof could cut those wires endangering the firefighter even more than climbing up onto a burning building's roof.
