There is something that is not very clear to me in terms of generation of usable power. I'll try to explain.
I have a 10KW system that feeds power to the power company.
Each panel has its own inverter and therefore the AC voltage is being combined.
So basically, the system is feeding AC voltage into the grid when it generates more than we are using.
I would like to use some of that power to charge my own batteries, but before it gets to the meter.
The part I don't understand is the amount of usable power depending on the amount of sunlight it is getting.
Is there something in the system that cuts off power if it is too low to be usable?
I mean, what if it's only generating 80V AC, how can that be used and does it ever happen or is there something that prevents power from flowing unless there is a certain amount of voltage?
So for example, if I needed 1000 watts to power my battery charger, if the voltage was too low, would that not potentially damage my charger?
Is it possible that my system was only ever meant to feed the grid and not be something I can use independently?
I have to believe the latter cannot be the case and that there is something I'm not seeing such as a combiner or something that controls all of this.
