Hi just starting to do this off grid living and would like to know what is best 48v or 12v.Also thing about a turbine more for winter.i know they have a different charger but can this be added to my battery bank that the solar are wired too? Thanks
12v verses 48v system
The wind turbine can be added to the battery, but wind is usually not worth the effort, at least I gave up on it for m case.
Lots of 12 volt and 24 volt DC hardware and accessories, but going to 48 volts even less. I like to limit loads to less than 100 amps, so think of:
12 volts for 1000 watts max usage
24 volts for 2000 watts max usage
48 volts for 4000 watts max usage
So, the size of this system really depends on a reliable power audit. -
Thanks for your answer I'm a bit of a novice on this.the wind well I live on the side of a valley and cause we get plenty.of that and sun to.atm I have 2x355w panals and one 375w panal attached to 4x125 amp lead acid batteries with a 60amp charger and powering off that is a pure sine wave inverter 4000w/8000w. What would you thinks best keeping 12v or change to 24v/48v???thanksComment
These are some good links to review:
Paralleling Batteries [] 12 Volt Safety Design [] Basics of OffGrid Design [] Batteries and Inverters
Same System Different Area--Huge Difference [] Mixing and Matching Solar Panels
My RV Build[] Off Grid CalculatorComment
Thanks for your answer I'm a bit of a novice on this.the wind well I live on the side of a valley and cause we get plenty.of that and sun to.atm I have 2x355w panals and one 375w panal attached to 4x125 amp lead acid batteries with a 60amp charger and powering off that is a pure sine wave inverter 4000w/8000w. What would you thinks best keeping 12v or change to 24v/48v???thanksPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
