I don't think so. it is plywood - 8" insulation - plywood - rafter. it is much the same as the image. my colleague suggest Unirac Flashloc RM or OMG Powergrip but i'm not sure if it is compatible with shingle roofing.
You can use RT-Mini's and attach to the plywood if it's 7/16" or greater
The RT-MINI with AlphaSeal™ RT-MINI is Roof Tech’s Self-flashing™ mounting base designed to attach conventional rail mounting systems and accessories including the conduit. RT-MINI is engineered to withstand wind speeds up to 180 mph and ground snow up to 90 psf. The main difference between RT-MINI and conventional fla
Almost all building departments require fastening into the roof structure. Surface mounts may work if you can get a manufacturer to provide a engineered document supporting this method.
Andy
thank you. I was thinking of this (RT mini) but i'm concern with the rigid foam to be compress. OMG powergrip is design the go thru insulation but it is only for flat roof
We've not had any problems getting them permitted with a structural letter from a PE. Also RT-Mini installation instructions show both lag into rafter and 4 bolt substrate mount.
