What are the best methods/products to clean pv panels with? Do the mounted spray systems work well? I am from Barrie, Ontario, Canada and our panels are extremely dirty.
Solar Panel Cleaning
I wash mine in the morning, before they heat up from the sun, and just use a garden hose and spray nozzle.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
ive heard of commerical systems using reverse osmosis filtered water just so the minerals are not left on the panel over the lifetimeComment
with automatic cleaning system that sprays out water to clean the pv system possibly 3-4 times a week -_-
tilted panels too...Comment
A garden hose, and a Mr. Clean Car Wash DI rinse water cartridge.
If you have tree sap and goo on it, you will have to figure something out for soap that will not eat the edge sealing.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Ivory or Dove liquid dish washing soap are about the most PH neutral wetting agents you can buy. Or baby shampoo.
If you cannot put it in your eyes, don't use it.MSEE, PEComment
If you are collecting rain water into tanks be really careful using any chemicals to clean panels.Comment
I have also heard of those, I have been researching that and the reviews for them have been good. Only problem is I live in Canada and the pipes will defiantly freeze and burst, there has not been any cleaning systems made for Canadian weather.
Mr Clean Car Wash kit, with DI rinse cartrige. <amazon>
Wash and rinse with tap water, then the final rinse use DI water, just like the spot-free car washes. no chemicals, just ultra pure water. I use it for 2nd floor window washing too.
Unhook from hose, drain and put away.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
