Yeah I've mostly seen it in the midwest, but that's partially because the midwest is in my region. I actually just learned how bifacial panels can help with snow mitigation, and it came from questions I had stemming from the recent Texas power issue. I think your theory for Florida makes sense, but I'm not positive. I'll see if I can find out more from some of our other regions. It's likely the company I work for has projects in Florida.
String system vs. Optimizer System
Yeah I've mostly seen it in the midwest, but that's partially because the midwest is in my region. I actually just learned how bifacial panels can help with snow mitigation, and it came from questions I had stemming from the recent Texas power issue. I think your theory for Florida makes sense, but I'm not positive. I'll see if I can find out more from some of our other regions. It's likely the company I work for has projects in Florida.Comment
true, or is it some much smaller secondary number? Please explain how a
panel mount can take advantage of bifacial panels, without any shadowing.
What does bifacial have to do with snow mitigation? Bruce RoeComment
In spite of the hype and innuendo bifacial panel mfgs. push, for most residential rooftop applications, reflected light does not get to the underside of any array that is close to the surface it's mounted on.
Claims of bifacial panels achieving significantly greater energy collection over monofacial panels and studies are mostly B.S. anyway, and especially so with respect to most common residential rooftop applications. Bifacials may have some advantages for some commercial or industrial applications, but even then it's very application dependent and not a slam dunk with respect to cost effectiveness unless the cost differential/panel (not $$/STC W) between the bi and mono panels is very small.
If an application is on a residential roof with a type of orientation we all know about and see all the time - parallel to a roof and a few inches or less away from it - bifacials are a waste of money because there's no irradiance worth measuring that hits the backside of a commonly oriented rooftop array.Comment
The term bifacial implies that the sensitivity is the same on either side, is that
And if that rooftop array - like most rooftop residential arrays - is parallel to the roof surface with something less than 15 - 20 cm clearance between panel frames and the roof deck, the irradiance the backside that array sees will be close to zero, making any already hyped up advantage a bifacial panel may have about the same, that is ~~ = zero, even if that array is sitting on a very high albedo roof.
I was more insinuating that advancements on the utility-scale would lead to better applications on the commercial side. My apologies for any confusion there.
I think your subsequent posts about orientation being the main driver for an advantage of bifacial vs. other models make sense. My understanding of bifacial panels is it's basically like a two-sided panel that would require an amount of reflection on the bottom side to receive the needed energy to heat the other side and melt snow or keep snow from accumulating. I don't know quite as much on the rooftop solar side of solar energy, so I definitely appreciate your insights there.
