advice on Monitoring Services
  • ajohansson
    • Feb 2017
    • 4
    So my Inverter died in July and I just found out because of my edison bill to the tune of 3600 dollars. The green light was on the whole time, Edison just takes the monthly bill direct from checking account. If i log in to solar edge it shows it makes power just tiny amounts. I got zero warning on this and it looks like my installer needs to give me more permissions to get alerts etc. Installer thinks the inverter died. I dont want this to happen again nor do I want to rely on solar edge to tell me if there is a problem. Any advice on solar monitoring. I really just need basic stuff like your not producing power and a notification sent to my phone or an email. Any help appreciated.
    • 5213
    My inverters have a power readout on the front, which I look at on
    sunny days. Lacking that, there are all kinds of inexpensive meters
    you could attach externally. If output is not there, I go after the array
    with other meters. Bruce Roe
      And you can always read your own Utility Meter, if it's set to count up and down
      • ajohansson
        • Feb 2017
        • 4
        Yeah I get that. SolarEdge has a nice app and all that and when I first got the solar 3 years ago I was glued to it and then it just lost I guess the wow factor. I am an idiot for not checking it more and looking into more of the notifications schemas available if it failed. On some blogs it doesnt look like the solar edge reporting is perfect either and the fact that my installer has to now give me more access kind of irritates me. My inverter does have a screen and some lights and when I found out my bill i went out to see what was going on and the green light that says generating power was on, I go to my app and its just miniscule amounts since July 25th. I can see the exact day and time it failed. Again I am an idiot for just assuming all is well but I dont want to stare at this thing all day either lol thats why I was checking on some after market stuff for notifications like if I am not generating for a day I get a push notification. I looked at Sense online but I cant tell exactly if they do that.
          • 15038
          Basic stuff: A little more self reliance might have been helpful in heading off the situation you describe. To help prevent a recurrence and as a kind of internal head's up, you might try reading your electric meter once in a while and see if the readings make sense.
          PV is good stuff, but some user input is required.
          • ajohansson
            • Feb 2017
            • 4
            yup i learned that the hard way. Like I said I was waaay into it when it first went in, watching my meter go backward, on the app multiple times a day. After a couple years the "excitement" went away and it was just working until well until it was not. Yeah I know I could set a reminder once a week to check my system but would prefer some sort of automation to check it that is not tied to the inverter but separate. Until then its gonna be a reminder in my phone.
              ......would prefer some sort of automation to check it that is not tied to the inverter but separate......
              I bought a Neurio which can be triggered by an IFTTT script and send a txt or email.. At that time (several years ago) it was the only thing available that could do that.
              • DanS26
                • Dec 2011
                • 991
                The TED monitoring system has the capabilities you are looking for......here's a screen shot of the notification setup in the system setup.......
                • ajohansson
                  • Feb 2017
                  • 4
                  DanS26 -
                  The resolution of your screen shot is pretty poor but I went to their website. Do I need the TED commander to do this? Looks like an app? Really just need a push notification to device if the solar system is not producing etc. Its 500 bucks but I just wasted 2000 because my system was down despite my inverter on the outside saying everything is good. I dont trust solar edge at this point at all.
                    • 5213
                    If 500 bucks but I just wasted 2000 because my system was down
                    Spend the big bucks if you need those functions, I would not trust it to still be
                    operational when you next need it. The DROK 80-300V I showed is around
                    $30 delivered from Amz. Here is another item capable of super reliable
                    monitoring, often seen as surplus for about the same $. Bruce Roe
                    • DanS26
                      • Dec 2011
                      • 991
                      Sorry about the resolution.....I live out in the boondocks of southern Indiana and my bandwidth is extremely poor so I resize pics. Above is the best I can do. Yes I got my Starlink order in.
                      I've had the TED Pro system for over 8 years.....before that I had the TED 5000 system. I monitor 28 individual power circuits in my home which include the Main power, two solar inverters and an EV circuit in my garage.
                      In your case you would only need to monitor the two main panel circuits but you may also want to monitor your inverter AC production circuits. I think the basic system can monitor 2 circuits so a couple of Spyders for the solar circuits would be wise to install also. You want the "TED Advisor" functionality of the system which comes with the basic system. I monitor the system on my desktop, my iPad and iPhone. I also have TED report my solar production to PVOutput.org every 5 minutes.
                      Yes its pricey.....~$500 and you have to install CT (circuit transformers) on the circuits you want to monitor. If you are not handy then an electrician may be necessary. The TED Pro Home would handle your requirements. The TED system uses PLC (power line communications) and does not play well with noisy power lines in your house. If you have noisy lines a conditioner may be necessary.
                      TED Pro Home Residential Energy Monitoring System. Get Free Shipping when you buy now from GlobalTestSupply.com.
                      ps. Just a bit of advice from experience. Install the system with a UPS (uninterruptible power supply)....does not have to be large but it will protect your data from power glitches that seem to corrupt data without it.
