Please correct me if I'm wrong.
The measured output per panel varies with location but is not patterned.
There is no shading.
The array puts out roughly the expected amount of power.
I just looked at the data sheets from a few optimizers and NONE give monitoring accuracy specifications. It is easy to measure voltage accurately and hard to measure current accurately. Measuring current consumes energy, so to get the efficiency high and cost low, they might have compromised measurement accuracy.
Is it possible that the optimizers are just really inaccurate at monitoring power, and you're simply seeing +/-15% optimizer calibration differences? I know that sounds like a lot, but it's within spec because there is no spec.
The ultimate test would be to swap optimizer locations. See if the high reading stays with the panel or stays with the optimizer. That requires disconnecting MC4 connectors, which requires either dexterity with little pointy things or a special tool. It also means FIRST shutting turning off the AC disconnect and THEN turning off the DC disconnect on the inverter, before you disconnect a panel or an optimizer. A string of panels produces a large voltage. If you do it wrong, it can cause a serious arc - with DAMAGE, INJURY, AND POSSIBLY DEATH.
As Bruce mentioned, another good test would be to measure the current coming out of each panel, not the current coming out of the optimizer. Be sure that you're not shading a part of the array when you measure. That test requires a clamp-on DC ammmeter, but doesn't require disconnecting anything and doesn't require shutting down the array. Not every clamp-on ammeter measures DC amps. For example, Klein sells three similar models. The $80 model doesn't measure DC amps but the $130 model does.
https://www.amazon.com/Resistance-Co.../dp/B019CY4FB4
