Inverter Grounding
    From DigiKey.com
    https://www.digikey.com/product-deta...302-ND/8119218 600v rating 25A 12awg $2
    • jeffy104
      • May 2020
      • 17
      #32
      Thanks. I was able to order one. VERY hard to find item. Hard to believe it’s not included with the inverter.
        • 5215
        #33
        Originally posted by jeffy104
        So now I’m searching for the fuse holder for the output ac line on the inverter. Can anyone point me in the right direction to a fuse holder that I can connect 12 AWG wire to? It’s only a 3 amp fuse but the instructions say to use #12 wire so I was hoping to find one that would work.
        For lower voltage wiring stuff, I rely on DEL CITY in Milwaukee. Bruce Roe
          But the 3A fuse is in the 120V AC output. Can't use a cheap automotive 32V rated fuseholder
            • 5215
            #35
            Right, choose the part rated for the ap. Del City is great for battery stuff, but they do have
            some high voltage fuse stuff. Bruce Roe
            • jeffy104
              • May 2020
              • 17
              #36
              The inverter came today. Testing resistance between the 12v input negative lug and the ground lug shows open/no circuit. Reverse leads same result. I would say that this inverter weighs as much as a half dozen or so of the units from the big box outfits.
                The sure sine is a beast of an inverter. It needs that 100A input fuse to be able to deliver a surge without blowing the fuse.
                And yes, the 3A 240V fuseholder is a odd duck tor try to find, they are about $1 in bulk, why they could not include one in the box, and instead risk folks not using one, or using a 32V one from the auto parts store is beyond me.
                • jeffy104
                  • May 2020
                  • 17
                  #38
                  SO for grounding I’ll have a relay controlled conductor joining one of the inverter outputs to the neutral in the panel. That should do it.
