Considering where to install the inverter (SunnyBoy 3.8-US-41) in my system. I'm currently planning to put it on side of house, just outside the guest bedroom.
So I'm concerned about noise/hum from the inverter coupling into that room; how bad is it ? And does it only occur when there's sun on the panels and it's outputting AC power, or any time it's connected to the grid ? If it's only when sunny, probably not a concern (since nobody is likely to be in there sleeping).
Otherwise, could flip off main panel breaker for inverter connection, at night when there's a guest. Bit of a PITA though. I suppose one could imagine a relay driven by a timer, that disconnects the inverter every night. (I did something similar for my water heater, worked out great). Not sure what the long-term effect would be of disconnecting the inverter every night though.
