I have a heat pump hot water (HPHW) tank, with two 5 kW heating elements that I would like to connect to the Solaredge Smart Energy Hot Water device, which is a solar diverter. I can put the HPHW tank in the electric only mode from 9a-5p. I hoped to control the electricity going to the upper thermostat with this diverter so that it would only power the upper electrode when there was surplus solar generated electricity. (I have an electric meter wired to monitor import/export). Normally the power connects to a control board, which then powers either the HP compressor or the upper or lower thermostat depending upon the mode setting (HP, Electric, combined or Vacation) and the temperatures sensed at each thermostat. The upper thermostat is the master thermostat and will energize first if the HW tank is filled with cold water.
Is this possible?
I called SE tech support but they referred me to SE design and Sales, who has not returned my calls.
Thanks in advance for any advice or suggestions.
Is this possible?
