bewildered by panel choices for DIY system
  • RShackleford
    • Sep 2019
    • 311
    #31
    355w is still going to take up some real-estate, be heavy and act like a sail.
    43 lbs, 68" x 40" , 20.3% eff
    Looks pretty comparable to the other panels I'm considering. Look at the snapshot of my spreadsheet I posted above.
    Places that make me "call for a quote" make me nervous though. Especially when it says stuff about wholesale rates for installers etc. Wonder if I can really see that $266 price on a paltry 15-16 panels to a DIY'er.
      • 15064
      #32
      If the half cells are twice as efficient, that might be true, but I know of no breakthrough allowing 355w panels to be smaller than 250W panels.
      If their spec sheet claims hold up, they might be a reasonable and less expensive (and available for DIY) alternative to Sunpower with respect to an identified need for a high power density for an application.
      S.P. still can have a higher power density at their top end panel (221 W/m^2), but for the same STC array size, the older, still avail. and still viable workhorse S.P. 327's at 200.1/m^2 will require more roof real estate than the REC 355's at 204 W/m^2 by just a bit. And they are not avail. for DIY.
      The REC is a bit bigger, 1.74 m^2 vs. 1.63 m^2 for the S.P., but a bit lighter, at 19.5 kg, vs, 20.6 kg. for the S.P.
      Still, the ~ 7% greater surface area for the REC panel is indeed an assembly consideration, especially on a windy day.
      • scrambler
        • Mar 2019
        • 513
        #33
        I do not know if they sell to DIYer, they may only sell to installers and quote based on quantity, but it does not hurt to ask
        • RShackleford
          • Sep 2019
          • 311
          #34
          Despite the impressive price for the density of the REC panel, I'm not sure it's worth it for me over something like the Talesun 270 watt panel at $0.36/watt. Also wondering if its low price is a reflection of quality, or simply typical for such a low power density.
          • nwdiver
            • Mar 2019
            • 422
            #35
            Agreed; If you're not space constrained and want the most cost-effective system I certainly would not pay >$0.40/w for panels.
            ~All panels and cells are manufactured to roughly the same standard. I've never seen a significant difference in quality. I would never hesitate to buy panels from a company with a large scale manufacturing plant.
