Just finished my install, 16 (250w) panels in two strings of 8. Solectria 5kW inverter mounted inside 100+ft away. Its reading less than what I hoped on both strings. Some issues with shading from trees and a set of high tension lines. I'm thinking of adding optimizers to increase efficiency and cutting down some trees. I'm trying to determine what optimizers I can even use. It sounds like solaredge HAVE to be connected to a solaredge inverter to even function. SMA may work but you lose any ability to monitor individual panels without using their brand of inverter?
Any experiences you all can bring to the table are appreciated!
