microinverter EMI value at 0 distance point.
My XW inverter has cleaner power than the grid. When your neighbor starts the skill saw, or welder.....Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Correct. I wouldn't worry about stray RF or EMF generated from solar equipment. For that
matter if is is approved in the USA it must meet FCC standards which limit the output noise
it can generate.
You probably get more RF and noise from a Ham Operator that is next door to you.
lifetime. It has the most effect on low band AM radios, HAMs do not like it. I went to a
seminar at FERMILAB attempting to quantify just where we are. It is true equipment is
supposed to meet regulations, but the original thought was that a few such items here
and there would not amount to much, once you moved away from them. What has
happened with transistor and SCR switchers everywhere, is we are saturated with
barely legal noisy devices, it is impossible to get away from them.
My own opinion over the decades of my HAM license, is that every device should be
filtered to the point it cannot be detected outside the same room. Yes that is usually
possible (as I have demonstrated), but industry does not want to pay the cost, and
the public is entirely ignorant of it. Bruce RoeComment
The fact is that some people installed solar getting this dirty electricity or their neighbors too
Is the because the solar was not properly installed by licensed contractor or something?
Have you tested your lines to see if it is clean?Comment
In fact the radio noise floor (not a danger to anyone) has been steadily rising over my
Long time ago I use to live next to a HAM and when he turned his "beam" in the direction of our TV antenna we would hear him talking on our set. His transmissions were also picked up on most of our radios. But again that was ages ago.Comment
Originally posted by SunEagleI am glad to see you are taking steps to reduce the RF from your equipment.
very narrow bandwidth. Sometime cheap nearby equipment cannot handle it, a cure is usually
possible.
Things like computers, dimmers, brush motors, and much more have no need to radiate at all,
but they do over an extremely wide bandwidth. The radiation is low, but they all add up.
Bruce Roe K9MQG since 1958Comment
I have a Fronius inverter and when it's operational it creates noise on the power lines throughout the house (a source of EMF in the RF range).
I also tested a variety of other solar PV systems with a centralised inverter and found they are all noisy.
Micro inverters ought to be a bit less noisy than a single centralised inverter?
Has anyone tested their micro inverter system for noise?
I have enphase iq7+ micro inverters. I have been working from home these days but I don't here any noise at all.
I also checked EMF in each room before and after installing solar system and there's no difference in terms of EMF.Comment
Thanks for confirming that Kevin.
Very few people know about noise, even fewer know that solar power is often noisy and even less measure the noise.
What testing method/equipment did you use to check the noise/EMF?
It was RF that got worst as the noise on the power lines increased.
The good ones use filters and shielding to contain most of the noise before it
reaches the wiring. My Fronius IG PLUS 7.5s were found to do a good job, no
interference to my radio equipment. If otherwise, I would have built a hardware
cloth shield around them with industrial level filters on connecting wires.
I do not see how micro inverters can compete and put in all the shielding +
filtering that a centralized inverter might have. I would expect them to be a
terrible source of noise which cannot be contained, since it is spread over the
entire array. Bruce RoeComment
These switching power conversion devices are inherently terrible noise generators.
While that motor may create noise when it starts it may not do so continuously. An inverter or just about any Switched power supply will continuously create noise or harmonics which will affect sensitive equipment and sometimes cause them to fail early. That noise can be through RF or Harmonics on the power lines.Comment
