Hello all
I am new here and also new to solar, my name is Keith i live in southern Africa, Zimbabwe to be specific.
i am planing on setting up a small solar system for my two bedroom house, Our Grid power has become very limited, we only get it from 10pm to approximately 4am.
I have done some research and watched the beginner videos on the DIY SOLAR CHANNEL. anyway i have calculated my consumption at 246watts this comprises of
1} 47inch TV @75watts
2) Modem 20watts
3) 8 LED House lights 7watts each Total 56 watts (these will only be on from 5:30pm to 10pm)
4} 1 laptop @95watts ( this will not be on all the time)
Because of the limited access to solar products here and my limited budget i could only afford to get a 1500watt hybrid inverter by a company in India, its a 24volt inverter with a built in 25amp MPPT charge controller the lable on the inverter specifies 600watts max of solar panels and i have secure four 150watt 12volt panels, it also specifies maximum VOC 50 and VMP 30-36.
The manufacture recommends using flooded lead acid batteries which are easily accessible here, i am planing on buying two 200ah flooded lead acid batteries.
We usually a good 6 solar hours, i need help, with two issues i have told by the company selling the batteries that the built in charge controller might not be able to charge charge the batteries sufficiently?
If that is true would someone be able to advise me if it will be possible to bypass the built in charge controller with one of the 40amp units that are recommended on the DIY Solar channel.
Thank you in advance
2) Modem 20watts
