Solar Set Up Help
With a single panel you will be fine with the system at 12 volts. If you ever want to expand the controller needs to be replaced, UNLESS, you want to go 24 volts, then you need to add a panel. Of course your inverter is only good for it's designated system voltage.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Your CC is limited if you decide to enlarge your system but your real issue is you now have a 12v battery system so a 24v inverter will not work.
You also now have a 400Ah battery system which will need about 40 amps of charging which comes to about 500 watts of panels.
Thank you for all the feedback! I could get a different inverter.
I am also thinking of getting a battery combiner as a supplemental way for charging the battery bank. So could that make up for having only 300 watts of panels?Comment
What is a Battery Combiner ?
A Solar PV Combiner is a fused junction box where several parallel PV panels are combined. It does not make any greater amount of electricity, it's merely a safe way to connect things together.
It's a device that connects your start battery and house batteries so that excess energy produced from the alternator will charge your house batteries but will also allow flow from house batteries to start battery when it sits. So you'll never have issues of draining the start batteryComment
That is actually called a battery isolator not a battery combiner.
It's a device that connects your start battery and house batteries so that excess energy produced from the alternator will charge your house batteries but will also allow flow from house batteries to start battery when it sits. So you'll never have issues of draining the start batteryOutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
