I think those things work by clamping the surge to ground. As suggested earlier, the issue in your case sounds like it is that the charge controller which can't handle the change in load. I would guess that an investment in a higher end controller would be more optimum.
Voltage spike on solaredge inverter
Surge suppressors can only handle millisecond surges, not the half hour overvoltage at dawn when panels are cold
The correct panel configuration or the proper sized charge controller is the best solution, not adding more parts that can failPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Yes, indeed, this appears to be the issue. The only problem is that I am just after purchasing this controller. The advantage that it has is that I can attach on 7.5 kW of panels and it limits it to 5 kW for charging the batteries. I don't need 7.5 kW in summer but I do need this amount in winter. Most days, during winter, it won't reach anywhere near 7.5 kW, but there will be days when it might.
Most quality MPPT controllers can handle being "over paneled" a bit. To be sure about your controller, use their Sizing Tool, and see if it's an allowable overpanel, or dangerously over.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
