I was wondering if it is better to wire my 4 solar cells in series or parallel. The problem is that a utility pole casts a shadow that will move across the panels as the sun moves across the sky. I am thinking in parallel, as the other three cells can still produce while one is shaded.
Series or parallel
That should work OK, If I have the same minds eye view that you havePowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
