A friend works for a solar company, they are tossing a bunch of panels, he says they only need a diode. This is getting beyond me, so I was wondering if someone with more knowledge on the subject will advise. Thanks, Doug
---------- Forwarded message ----------. The panels- file:///home/chronos/u-83d974fbc2dab1682c54aab50cec65cc4d043e5e/Downloads/Hanwha_Q_CELLS_Data_sheet_QPLUS_L-G4.2_330-340_2017-07_Rev04_NA+(1)%20(1).pdf
The J box part number is >>
GF20X
http://www.renhesolar.com/products1-tid-20.html
The part number for the original diode in the J box >>
ZJRH HDD624
PST4020
I have found this diode do you think it will work?
https://www.mouser.com/Semiconductors/Discrete-Semiconductors/Diodes-Rectifiers/Diodes-General-Purpose-Power-Switching/_/N-ax1mp?P=1z0w9wk&Ns=Peak+Reverse+Voltage%7c0
I don't understand why panels need electronics between them and the inverter.
Do you have a suggestion or part number on what type of diode/MOSFET I should use or perhaps a few criteria to look for?
Thank you for your help in the matter.Thanks, Doug
GF20X
ZJRH HDD624
PST4020
