Sunrun Installed Storedge Inverter on GSM
  • Mattmitz
    • Jul 2018
    • 6
    I just recently had Sunrun install my solar panel system with an LG RESU battery. They installed a GSM monitoring package with the system and I have now learned the limitations of this system (4 updates/day). I have choose, based on the sound advice from you all, to order a powerline adapter and the necessary equipment to establish a LAN connection. Couple of quick questions before I perform the install:
    1. Does opening the inverter potentially void any warranty from Solar Edge or Sunrun? I'm assuming Sunrun will be able to at the very least see that the connection has changed from GSM to internet based.
    2. What are the bst recommendations to get consumption information for my house?
    Thanks in advance for your help.
  • ButchDeal
    • 3802
    No opening the inverter does not vid the warranty. You want to turn off the inverter ( on off switch) then dc disconnect, then ac disconnect before opening it.
    For monitoring consumotion you will want to get the wattnode consumotion meter that soaredge resells as the consumotion meter.
