I've got a SolarEdge SE6000A and have had it up and running for about a year at this point. It was originally installed with the GSM kit until I realized the limitations of that, so I installed a WiFi bridge in the garage and ran an Ethernet cable to the inverter.
Every once in a while I would get a notification from SE stating that it hadn't received data in more than 2 hours and it would clear itself. I think I got that maybe 3 times in a year.
However, over the last 2 weeks, it has happened a ton. I just tested connecting my laptop to the WiFi bridge instead and it is just fine (i.e. it's not the bridge). Sometimes the inverter will report not even being able to get a DHCP address. Currently it is in a state where it has an IP address, but all the pings fail. I can ping the inverter from my PC, so the network connectivity is fine. I did a packet capture on my router and there are no packets coming from the inverter at all, even when it is supposedly running its tests.
Earlier this week I restarted the inverter after sundown and it immediately cleared up the issue. However, now it is back. I don't want to restart the inverter in the middle of production, so there's not a lot I can do. Even if I don't reboot it, I have no doubt it will suddenly start working this evening
I do wonder if it is heat related at all as it is quite hot outside.
Has anyone else seen this kind of behavior?
