Announcement
No announcement yet.
System setup: Off grid solar, w/generator backup
  • Filter
  • System setup: Off grid solar, w/generator backup
    Hey fellas. First time poster and new to the solar world.
    I've been working on a setup for my small remote cabin, and I'm trying to figure out how to wire a portable gas generator into my solar setup to act as a backup. I don't know if I can bring that power in through the charge controller, or if I bypass the charge controller. Anyone have any idea how I can make that work together?
  • #2
    Welcome.
    Some of the larger inverters, also have an onboard charger, and connects to your generator. This provides pass-through AC power, and charges the batteries when you run the generator.
    Otherwise, you buy a generator and a golf cart battery charger and charge your batteries with an external charger, and simply do the Bulk stage of charging to save fuel, and let the solar finish it when there is sun. You do not alter your PV or PV charge controller at all, you would simply wire in the other charger to the batteries. You do have to insure you have the voltage set properly.
    • #3
      Appreciate the feedback guys. One point I forgot to mention, my system will be primarily 12 volt, and only have a couple things inverted right at the point of usage, like the TV stuff, and the air conditioner. Does that change the advice at all?
      • #4
        You still need the generator for the Air Conditioner and you can use any automotive charger sized to your battery bank - about 10% of bank, so if you have a 200ah bank, you need a 20a charger, maybe 25a. At 14 charging volts, 25a x .5 FP means you need a 700W generator just for charging and then more to run the air conditioner. Most little inverter generators may not be able to start a air conditioner's compressor motor, likely 3kw needed for that.
        • #5
          Very very bad idea.
          Let's take an example. You have to run 50 feet of wire to your A/C which takes ~10 amps.
          120 volt case - 50 feet of Romex 14/2 (12/2 if you want to reduce drop a bit.) Fine for 10 amps. Voltage loss is about 1.5%, which is fine (most people target 3% max.) Cost - $30.
          12 volt case - 120 amps (120/12 with some inefficiency thrown in due to inverter.) To get to a 5% drop (which is still a bit high) you will need 4/0 wire. That's $1 to $2 a foot. Cost - $100 to $200.
          And that's just the wire. Everything else (protection, lugs, conduit if used) will have to be larger as well. Plus you'll be drilling enormous holes in your studs.
          • #6
            Another user stuck inside a 12 volt toy box.
            • #7
              Originally posted by jflorey2 View Post
              Very very bad idea.
              I should take a step back and describe the entire project. I am getting a 15x40' prebuilt storage shed. It will be split in half and be half attached garage, half living quarters. My power draw will primarily be LED lights, some USB charging outlets, a 12 volt ceiling fan, a 41 watt TV, an antenna booster, and perhaps one or two extra outlets for charging fish finder batteries. All appliances will be propane (furnace-no blower, oven, stove, fridge, freezer, coffee maker). There will be no toaster, microwave, electric coffee maker, etc.
              I've done a power worksheet to see what my amps/day would be, and I've got it down to around 53. Now as far as the air conditioner goes, that would run right off the generator, it would not be hooked to the solar in any way. I've gone back and recalculated my array, and I think I can get it done with a 300 watt array to start, and a 400 amp battery bank.
              I am in a weaker solar area being in the far north (Grand Rapids, MN). My power draw would be lowest when the solar power is the lowest (winter). I'm now reconsidering the backup charger all together, on the assumption that I can get upwards of 4 hours of good charging during my peak usage times (May-September). That would put me around 100 amps a day generating power, with a consumption of 55-70 amps/day.
              As of now, I think i'll forget the backup charger. Worst case scenario, no tv for the day. Oh well, the whole point of this place is to be outside doing outside things. I've attached my floor plan for the fun of it.
              • #8
                ....d I think I can get it done with a 300 watt array to start, and a 400 amp battery bank......
                400Ah battery needs at least 40A for charging Best you will see from a 300w array is 21A Even 600W would be cutting it close.
                • #9
                  Well that was a nice Academic exercise. Just one problem, it will not work, especially in Grad Rapids. The battery needs to have at least a C/10 charge current and with 300 watts @ 12 volts is just 21 amps or C/19. To generate C/10 or 40 amps will take 600 watts in Grand Rapids. Use 300 watts and you will be replacing the battery every 6 months or less and spending a lot of time in the dark wondering how academics could be wrong.
                  • #10
                    OK. So that means you'll need an inverter. I would strongly suggest you get a decent inverter/charger so your generator can also charge your battery while you are running A/C. Your batteries will last a lot longer.
                    I assume you mean 53 amp-hours a day at 12V, which is ~600wh/day/
                    Well, no, worst case is a sulfated battery pack within a few months.
                    If I were you I'd treat the solar as a battery maintainer and rely on your generator to provide most of your power. Your solar will then keep the batteries from going dead and shorten generator runtimes.
                    • #11
                      That's why I came to you guys. Looks like I've got a lot more to learn. Appreciate all the help guys.
                      • #12
                        Is that universal info? For example in an AGM battery vs a lead acid battery?
                        • #13
                          AGM batteries have lower resistance than flooded and can charge at higher rates.
                          • #14
                            AGM batteries also cost 2x as much, and last only half as long as flooded. Only a good choice in special circumstances.
                            • #15
                              SD51555: Full time off grid here. I understand your desire to make this venture successful, but I think that you may have underestimated the some of the items to consider.
                              1. Are you living in this cabin full time? Part time? Seasonally and for how long?
                              2. Is grid power available, if so why do you want to attempt a solar powered system with batteries?
                              3. What are you doing for toilet, shower and water supply?
                              4. Have you taken into consideration the heating requirements of the new structure. Have you done heat loss calculations, etc. What R values are the walls, floors and ceiling.? What are the actual local costs for propane? Here at over $2.75 a gallon, limits my use of propane to the water heater, and stove/oven, and main backup 20kW generator. I use wood to heat the house. There are propane lanterns built into the walls by the original owner prior to installing electric power via generator and batteries, and later on the solar arrays, but have not used the propane lanterns. I use an electric refrigerator, but I think the specs on a full size propane fridge is about 1 gallons every 3 days or so. So what size of propane storage do you plan on getting since prolonged winter isolation may prevent winter deliveries of the propane? My sister in North Dakota has like a 2,000 gallon propane tank, while I only need a 500 gallon propane tank.
                              4. I think that you are way underestimating your solar power generation and possibly your proposed battery bank. Winter production at your location with solar is practically zero for 3 months nov-jan. See the link for Lake County: http://egauge14464.egaug.es/index.html, on the purple bar, select 1y. I live in one of the best winter insolation areas of the USA, southwest New Mexico, 5.5 hours winter insolation. Lots of clear blue winter skies. My FLA battery bank weighs 1,500 pounds, and I admit it is over batteried.
                              5. A 12-volt supply/distribution system may not be appropriate for the cabin. You may want to consider a 24 vdc supply with a 120 vac distribution system.
                              Good luck on your project.
