Anyone ever used such an inverter ?
Seems to be handy for simple system or not?
Specs:
1. Built-in solar controller, can charge for battery and convert DC12v to AC 220V. 2. Adopt PV-charging control system, it can charge automatically.
3. 3.0 LED screen display.
4. Battery reverse protection.
5. Universal socket, suitable for all kinds of plugs
6. Modified/Square waveform output
7. Applicable for resistive AC loads
8. Multifunction control system, including automatic PV-charging, high voltage cut-off, low voltage cut-off, short circuit protection, intelligent cooling function, ect.
9. Cooler of fan and working status are intellectually controlled by MCU, which mostly prolongs its service life and helps to save the power consumption
10. Gained CE,CTA,ISO,RoSH certificates guaranteed.
11. 26 years' experience in home power supply industry
6 safe protections are designed to ensure the safety of the power inverter and the electric appliances ,including overload protection, overvoltage protection, low voltage protection, high temperature protection and output short circuit protection,battery reverse protection.
I can buy it here for +/- 100usd
Specs:
