Thanks to all in my last post, who helped make my rack better with their suggestions.... it is ready to populate with dodads and string....
I used the No-Ox-ID on all the connection points and rail splice screws etc and the Nikel anti seize on all SS bolts. Rails are not torqued in place yet -waiting to space with panels.
I am working thru the electrical details, getting the boxes mounted and ready to pull the wire.
I have 20' of #4 as a EGC in the #2 ballast block (E=1, W=4) next to the inverter pole. I plan on running the additional #4 up the pole and perpendicular down the rails to ground the mounted equip. components.
I know grounding is a complicated issue, so I will have a lot of questions. I am reading thru the code several times. Even though we use NEC 2011 I have gotten APS engineering (who recently decided to look at my 3-Line again) to OK using NEC 2017 for my PV system since it is ungrounded DC and addressed better by 2017.
First question is: Do I have one big lightning rod sitting in my yard and how can I protect the PV system - or is the #4 connected sufficient. The local electric pole have strike devices at their tops - they are much higher than my rack and the closest are about 100' away - will that cover me?
Q2 - My inverter equipment ground... I had planned on just hooking it and the metal pole to the #4 that is running up the pole but 250.58 indicates I may have to tie back to the system ground at the house 70' away... but 250.54 confuses me on that point. APS is uncertain and will let me know next week - so what is your opinion? can just ground the inverter equipment jumper to the UFER- what is the danger of not bonding either of them back to the house ground?
Q3 - I am using the IronRidge microconverter/optimizer bonding T-bolt mounting kits to attach the optimizers to the rails. I seem to be reading a lot of other posts indicating intermittent or failure of optimizers to report, function etc. I'm thinking maybe their ground isn't as good as it should be and maybe I should run a ground wire between them as shown in the Solaredge tech note. But I don't want to be running exposed copper all over my nice aluminum frame, so i figure I could use insulated #10 and bare it at the connection points.... what say y'all?
Thanks
Al
Thanks
Al
